Axle spline wear question
Ds18425
Boerne
Hello Guys/Gals,
Im rebuilding my 74 9" rear end. I need your help with my axles. Are these axles worn out? I an not sure is there is a specific measurement i can take.
thanks in advance!
nvrstuk
PNW
IMO, nope... really common on the 28 spline to get a little twist/tweak (if that's what I'm seeing in the first pic).
28 spline (stock) axles are notorious for twisting the splines off. But there are tens of thousands of them still running around out there. I was going thru them regularly... :)
B RON CO
Statesville, NC
Hi, X2. I wouldn't worry about it. If an axle shaft is twisted badly at the splines it could be really hard to remove. The Ford nine inch rear is s rugged unit, but when it breaks, it breaks. Good luck
Hard to tell in the pictures, but it looks like the splines are getting a shark fin profile to them. They should have a symmetrical profile.
I think those are getting toward the end of there life. And the side gears in the diff will have a matching wear pattern.
What size tires and how do you use the Bronco? And just as important, what is your current and expected gearing?
I'd say they're on the fence too. According to the factory books I've seen, that pattern is considered "worn and out of spec" and the typical recommendation is to replace them.
However I'm with the others that say they're perfectly serviceable in a Bronco that sees normal to light use.
They're certainly on their path to old age. Just not ready for the farm yet.
But if you were using them under heavy loads (such as poor gearing for the tire size), or have a locker, or even limited-slip diff, or big tires, or have built your Bronco rugged with heavy metal all over it, it's time to upgrade to a higher grade 31-spline setup no matter what.
I guess too, that if you like to do regular burnouts with your new stroker engine, that would totally justify replacement shafts now.;)
D
Ds18425
Boerne
Thanks for the info!
Plan on putting 33's on it. Gearing is 4:11 and will just drive around town with the occasional off-road at the ranch. Nothing hard core just some steep hills and occasional mud.
you folks are great! couldn't do this restore without you!
I would not put money into that axle, but I would just put it together and run it as is.
With the idea that a new set of axles and a new diff will eventually be needed.
The failure mode should just be a loss of drive when it strips out, but the wheel should not fall off. So just run it. Don't be surprised if it goes. And in the mean time just keep an eye out for some good deals on 31 spline parts.
broncodriver99
Glen Allen, VA
They likely have a little life left in them.
I have a set in similar condition up in the rafters. I replaced mine when I was rebuilding the rear and doing a gear change. Kept the old ones as backups just in case one day... As was said I wouldn't put much money into them.
I ended up just sticking with 28 spline as they are more than sufficient for 33's and it just worked out that way. Long story, it snowballed.
blubuckaroo
Grease Monkey
Ridgefield WA
The bigger question is about your differential.
A factory limited slip uses only 1/4" of the splines on the left side axle to drive the whole thing. It's a really cheesy design. Lots of the left side axles are stripped on that first 1/4".
An open rear end however, contacts a full inch of those axle splines.
D
Ds18425
Boerne
Yepper it’s the two gear posi. Think I’m headed for a Complete rebuild. Its already apart and I’d rather spend money for the long run. Any suggestions on what type of locker? Tru track?
nvrstuk
PNW
HUGE can of worms on rear diffs...!! LOL
Do a quick search OR just scroll down the 1st page of posts for recommendations on a Locker...lot's of opinions...
