35 spline axle question
Pops
Warsaw, In
I have a medium bearing rear end. I am getting ready to upgrade to 5.13 gearing and am wondering if 35 spline axles will fit in the torino bearinged
9inch rear end? Or an I limited to 31 spine ?
Thanks in advance for any info you mite have.
Pops
GubNi
Northeast TN
Why bother? 31 spline is plenty. I've got a friend with 31 spline and 38's with a locker. If you need bigger get a 14 bolt or Dana 70 so you can go full float.
Pops
Pops
Warsaw, In
I am trying to follow the rule only break it once. This is my daily driver/trail rig. Down time really sucks.
welndmn
Yes, there are some conversion bearings to run the 35 spline axles in that housing, but don't forget, you need to upgrade your 3rd member as well.
I would call up Currie and talk to them. It may be better to just swap a Big bearing rear end in.
Pops
Pops
Warsaw, In
I have a 28 spline detroit locker with 3.50s in it now. So the 28 spline will be swapped into my 1970 Torino gt. So since I'm replacing it anyway I want to go as big as possible. Replace things once.
Thanks for the info.
br0nc0xrapt0r
Loves pickles
no I'm pretty sure he means you need a nodular third member housing to fit the 35 spline carrier, I just did the research and a question post on this topic and unless you are going to run a spool I don't think it will be possible to find a locker to run 35 spl shafts in a stock 3rd housing.
hope this helps.
Dusty
I used to run 35-spline Currie axles in my '75 torino-style housing. Give Currie a call, they'll set you up. Mine had tapered roller bearings.
Dusty
Dusty
Of course it was. I never had to worry about breaking itty bitty 31-spliners :D
I sold that housing and axles a few years back but kept the nodular center, re-used it in the big bearing full width 35-spline 9" that's currently under my wife's rig "Coco".
Dusty
NC-Fordguy
Bethel/Greenville NC
I'm running 35 spline on a 74 big bearing.
You'll have to get a new carrier/locker and 3rd member.
Wasn't a big deal for me to get a new 3rd as when the 28 spline axle broke it destroyed the detroit and ring gear
Bronchole
Chatsworth, Ca (LA)
If you are in touch with the fact that in going 35 sp you will have to replace the case and the locker/spool the total build cost wetween going 35 or 31 is only something like $200 on $1200 worth of parts. If I were starting from scratch, upgrading from 28 spline, its a no-brainer. But if I already had a 31 spline Detroit locker, I'd have to get decent money for the used Detroit locker to consider not upgrading to the 35 spline everything.
BTW, Summit Racing a few years ago had the sweet deal on Strange Engineering "econo nodular" cases. They are only a few times stronger than the factory Ford nodular cases (which are far stronger than the standard Ford cases) but in my opinion they are pleanty strong enough. They are in the mid $200 range delivered to your door. Food for thought when you are going to be looking at nodular cases in the $450+ range anywhere else.
Dan
