There's a big differnace between diesel engines and gas engines yes some gas engines can be run at fairly low RPM's but it will never do what a diesel does. your loss in mileage proves that gearing is not there.
You want gas mileage then get a car. Put some half way decent gears in that thing a build the engine a little. Its more about matching components than it is just trying to run low RPM's. 456 gearing would probably be a good choice that will still keep the RPM's down and give you way better low end power not to mentyion good hiway cruising RPM's. You might find that you dont have to run in low range very often anymore so it will be availible when needed. Plus the better gearing will allow the clutch to live longer and you wont have to down shift on the hiway when you hit a hill.
While swapping to the cam you listed may help on the low RPM side your still not going to make anymore power than a stock cam. You just move the power band around a little if any. Almost every other aftermarket part out there really only makes more power at higher RPM's so usually from about 1600 RPM on up. adding heads wont help as they alone usually move the powerband up 400-700 RPM or more.
