351w efi fuel rails ?
DEEPWOODS
351W with EFI is it best to have the fuel rails hook up at driver side rear or passenger side front? Also I will be using explorer front dress. Please Post up some pics of yours Thanks Keith
Bronco Brian
You will have to run a spacer under the upper intake for the Reg. to fit in the rear. And that will also require a body lift of at least 2". I like the cleaner look of a rear Reg.
tatersalad
you will need the bcb spacer, an after market upper/lower or a lightning lower and 5.0 upper to run that setup. I did squeeze mine in without a body lift however i have a pro flow stye fiberglass hood. I do plan on a one inch though because the passenger side long tube header is close to my wife's feet
fordtrucksrule
I used the 89 mustang fuel rails. i cut the plastic line between the rails and used a piece of rubber fuel injection line i think 5/16 and put them back together.
70_Steve
Old Guy
I have a GT-40 lower and Explorer upper. I eventually used the standard 5.8 truck fuel rail so I could have a rear regulator and drivers rear fuel line connection. But it took a bit of "massaging" of the connections to get it to fit. On my 70 the connections went straight into the wiring harness firewall connectors.
Mock up the upper and lower with your fuel rail to see if you need a spacer between the upper and lower for regulator clearance. If I remember, the stock regulator fit my combo, but I went with a BBK adjustable regulator which required a 3/8" spacer. Even with that, if I need to adjust the regulator, I need to remove the upper manifold.
Z Bronco
What about the Explorer fuel rail, that is another rear passenger side fuel inlet/outlet option.
DEEPWOODS
DEEPWOODS
I am using a 351W Cobra intake upper and lower I don't have any fuel rails yet I want To do this once. Need to see pics
DEEPWOODS
DEEPWOODS
So 70 Steve Is saying his rear went straight into the firewall harness so is front connection best like 88-93 mustang?
Amac70
ME
Im running a a truck style fuel rail with regulator in back and don't have any clearence issues. with the fuel rail and wirring. I did have issues with the upper and the wirring harness. All is fine now but i think i will end up raising the tranny about 1/2-1 to make everything fit a liittle better.
You can also do a no-return late Explorer rail and put the bypass regulator where you like in the supply line before the rail.
DEEPWOODS
DEEPWOODS
How does the no-return work Is it a different fuel pump?
You use it as a return setup. The difference is the line to the rail is a single line instead of a loop.
What you have to remember is the pressure regulator is a simple bypass regulator. Once the fuel pressure reaches the desired level it will vent the excess fuel into the return line to go back into the tank. It doesn't really matter where in the loop the regulator goes. Engine compartment is best as it gives you the short vaccum line to run as the reference vacuum to the regulator.
Many new cars have fixed fuel pressure (no more vacuum reference) and the regulator is in the fuel tank. The complete loop of pump, regulator, return is all in the tank. There is a single line that comes off the pressure side and goes to the fuel rails. For new cars it is a way to control evaporative emissions (not returning hot fuel to the tank), safety as there isn't a return line that could rupture and dump the fuel load while teh engine runs just fine, and cost as they only have to run a single fuel line. But they have way more sophisticated computing power to manage fuel delivery without using a vacuum regulator to maintain a fixed delta of delivery pressure.
The stroked 5.0 I put in the Ranger several years ago was done with a no-return fuel rail. the supply and return lines came up near the master cylinder. Regulator was placed near the drivers hood hinge. The supply from the pump fed into a "Tee" fitting. One leg went to the rail, the other to the regulator. The regulator manitained the pressure setting in the line and rail and sent the excess fuel back the return line. Vaccum line was only as long as needed to get to the regulator. Simple way to keep the regulator off the engine.
DEEPWOODS
DEEPWOODS
Tim, if I am getting this there is a return on the regulator and only a supply on the fuel rail with just one cross over pipe. About what year explorer had these fuel rails with 5.0 ?
DEEPWOODS
DEEPWOODS
Tim this is the explorer engine I have in the basement I am not going to use. Is this the no return rails? It has two cross over pipes in the back none in the front see pics
That is an older return style Expolorer fuel rail with built in regulator.
Easy to spot as it has supply and return lines.
HGM
Senoia, Ga.
Keith, I'll have to double check when I get to work. But, I believe you'll have to go to '01 for a returnless 5.0L... If you look at your spare, even in the pic's, you can see the regulator on the rail and two lines connected to the rail. One feeds th rail, all injectors, then after the regulator, it returns to the tank. It wouldnt be as clean, but you can use that rail and plumb it like BB suggests. You'll just need to block the return line at the engine. The thing is, because the 5.8 is wider, the rail would have to be modified anyhow, so while modifying, you can simply eliminate the return hose, just make sure it doesnt leak!! At this point, I've still got the 5.0 sitting in mine and plan to just plumb it as a return system, because its how it was designed and the return rails are already there, easier to find a return 5.8 rail too.. May change my mind as time goes by, but thats where I'm at.
HGM
Senoia, Ga.
'99-'01 5.0L Explorer's were mechanical returnless systems and have the rail you would want. But, it still will not fit the 5.8L w/o reworking the hoses that connect them.
mattt
Basically if you want a rear mounted regulator, you have to have rails that have the regulator on the same side as the throttle body. First gen 5.0 Explorers have fuel rails with regulator on the passenger side.....all 351w truck rails I've seen have the reg on the drivers side, but that works with truck intakes facing drivers side. Explorer fuel rails are mirror image of truck rails....only bummer about using Explorer rails on a 351 is you have to re-do the cross over tubes because they're not wide enough for the 351. I used truck rails on my 351...driver side facing tb....no body lift, no spacer, no special anything for everything to clear. I do have a Highlander hood but that is for upper manifold clearance only because no body lift.
I prefer the rear mounted regulator for it's clean install and not having fuel line running all the way to the front. Front connection rails work, but then you have longer fuel lilnes and lines that have to cross over from the drivers side frame rail....unless you run them up that side. I chose to run all wiring & lines down the drivers side frame rail and have exhaust only on passenger side to keep heat as much away from fuel lines as possible.
The 'wire harness plug interference to return line connection' 70Steve mentioned is for real....depending on what year your Bronco is. Mine is a 69 and has the rectangular firewall plugs right below the throttle linkage.....that is right where the return line fitting was pointed....until I massaged the fuel rail return line fitting. I'll attach some pics, but they are dark and hard to make out...hope that helps. If you have pass. side facing tb and want rear feed & return lines, I'd go with Explorer fuel rails and modify them to fit the 351.
Dude seriously
Everett
Would this work with an '89 MAF EFI system that originally had the regulator on the rail?
I like the idea of putting the regulator on the firewall and plumbing the return line from there.
Don't see why it wouldn't. Worked on the 5.0 mustang based EFI stroker that I put into the Ranger.
