I guess I could have rotated mine 90 degrees which would have moved the TPS to the side, IAC to the bottom and linkage to the side. That would have cleared my hood but then I would have needed to figure out the linkage vs. using the BC bracket and cable. Also seen to recall reading that some had issues with IAC on the bottom. Not sure what that's about.
I'm sure others have more info on what TB to use and what linkage will work once clocked. I got the explorer stuff super cheap so ran it. Explorer is 65mm as I recall
Tim
