I’m hoping, but not holding my breath here, that the fix is at least something I can handle in my garage… but here’s the issue-
I noticed some brown gunk in my coolant overflow and decided to see if it was related to a possible blown head gasket. I tried a head gasket leak test with testing fluid tool inserted in the radiator. No color change. The coolant system was bubbling up as it got hot, I assume it’s just pressurizing normally. Then I did a compression check. One of the cylinders was 25PSI off the rest.. eek. Then I poured a tablespoon of oil in that cylinder per other google suggestions.. and it jumped up to about 140PSI and matched the other cylinders. How screwed am I?
