- May 28, 2013
- 1,835
Just picked up at rebuilt 351w roller long block and need recommendations on oil pan and distributor.
Looking at these oil pans and all seam to be the same product. Im concerned about the comments of leaking of drain plugs. Also, I haven't found a pan that will accept a high volume oil pump. Not that its totally needed.
Are there better options out there?
As for distributor. I would like to run my current stock Durispark electronics 'if possible' and I believe I will need the distributor gear to be melodized (spelling?) Also, I may go EFI later like, FAST, ProFlow etc.
This is the came I'm running.
Thanks,
FORD MUSTANG Ford Performance Parts M-6675-A58 Ford Performance Parts Oil Pans | Summit Racing
Free Shipping - Ford Performance Parts Oil Pans with qualifying orders of $109. Shop Oil Pans at Summit Racing.
www.summitracing.com
351W Oil Pan Kit, 66-77 Ford Bronco
Check out the deal on 351W Oil Pan Kit, 66-77 Ford Bronco at WILD HORSES 4X4
www.wildhorses4x4.com
Xtreme Energy Computer Controlled 206/212 Hydraulic Roller Cam for Ford 5.0L
Xtreme Energy Computer Controlled 206/212 Hydraulic Roller Cam for Ford 5.0L (For EFI). Good power in stock applications with few modifications. Best for towing or economy. (Note: for 1985-95 Engines Originally Equipped w/ Hydraulic Roller Cams.)
www.compcams.com
Thanks,
