Jerrod4567
OK so I started assembling the 393 today. I have a 9.503 deck heigh block, Eagle 3.85 "Cast Steel" crank, 5.95 351W rods and Speed Pro 272AP 302 pistons .030. I mocked it all up and discovered I will need to notch the pan rail for the rod bolts (no biggie) But what I discovered next was that the Piston skirts hit the crank throws. Whats even more weird is this. The piston at TDC sits about .045 down in the hole. Something here is not right. I'd appreciate any advice about this situation.
