RnrdTheFox
I'm in the process of digging into this build for a winter project and a I have a few questions.
Plan thus far is as follows:
- 94' or 95' 351W roller from a JY truck or van
- Ford EFI with lightening lower and explorer upper
- 4r70w tranny, Dana 20, 4:56 gears
- Cam TBD, but Comp Cams tool comes back with (35-510-8, 35-308-8, 35-349-8, 35-320-8) Need more investigation
- AFR 185 heads, 58cc, Eagle stroker kit
Questions:
- I want to use my explorer front dress so I have to deal with the 50oz vs 28oz damper issues. I'm leaning towards having the whole assembly rebalanced for 50oz. But, I could also have the damper rebalanced to 28 oz and purchased a pre-balanced stoker kit. How does this affect my current flex plate ('97 explorer 5.0/4r70w)?
- What size fuel injectors? 30lbs or 42lbs. I guess I could just say 42lbs and know that i have overhead. What is a good JY donor for each?
- EGR. I currently use my EGR setup with my explorer (early '97) intake. I would like to use it with the stroker and the lightening lower. Since it's internal to the intake, I think this will work with the lightening lower, correct??
- How do oval port headers work/seal with the square ports on the AFR heads? Currently I'm running oval shorties with the stock explorer 5.0 heads that are square, but I have always had some exhaust leaks. I want to clean this up when I swap the new motor in. I'm not opposed to spending some money on something like the BC shorties, but they are oval also. What have others done with the AFR heads and shorties??
- What is the torque converters stall speed for the stock explorer TC? Should I consider one with a lower stall with the bigger engine and torque?
- Cam recommendations?? I want something that is streetable, EFI friendly and that will compliment the engine.
- The engine builder was recommending a roller rocker for reliability, ease of setup, wear and tear. If I go with a roller rocker setup, any reason not to just buy a kit with the cam?
thanks,
Renard
Questions:
thanks,
Renard
