3g alt
Thanks for the kind words.
And I'm one of those that did have issues with slipping belts until I installed a dual-groove pulley. However, it may just be that my large case 1G simply had more mass to move, so when it was under heavier loads, even just the usual 30-35 amp load after startup, it was just too much for the traction of the belt.
You can only tighten a belt up so much before you start overloading the bearings, so I opted for the dual groove instead. With no power steering, it was a no-brainer.
I got mine from Ford for about 4 bucks, but you can probably get them at any auto parts store that's willing to order one up from one of their suppliers.
Perhaps with the slightly smaller (lighter too?) spinning parts in a 3G, fewer people have the problem.
Don't know, but it sounds plausible.
It's probably one of those other things we should stock, but the overall demand would be so low it would be hard to justify. Especially when it won't work for most people right off the bat.
What I mean by that is, with the commonly used dual groove/sheave water pump and crank pulleys, it would be hard to get two belts on the alternator if you also had power steering. Which more and more Broncos do these days.
So it's a catch-22. Good idea, but hard to implement in many cases.
A possible alternative in those cases would be a larger diameter "racing" pulley. Bigger means more belt contact area for more traction. The trade-off is that it spins the alternator slower.
However, with the very high output of even a stock 3G at lower rpm, it seems likely (to me anyway) that it would not lower the output potential enough to be a problem.
Anyone have experience with a larger V-groove pulley on a 3G yet?
garberz
Bronco Influencer
Conejo Valley, Ca.
... What I need now is a new 3G, because mine just quit on me this week.:(
Can you test to see if it's just the regulator? If so, they're relatively inexpensive and relatively easy to replace.
If it's one of our 1-wire conversions, we keep those regulators in stock too, so you won't be left waiting.
For too long anyway! %)
Good news for me. Turns out, it was just my battery was bad. I was measuring voltage with my analog multimeter, it isn't accurate enough to show between 12.5v and 14v. After charging the battery and checking, the battery was dead the next day. Rechecked with a good battery that measures 12.5v then 14.4v at idle, I checked with my friends digital meter. Something else I need to buy.
ryansbronco
The place of bronco
for occasional use
http://www.harborfreight.com/7-function-multimeter-98025.html
cheap and works
If you plan on doing more test and or other things than just the bronco, I'd look for a used fluke.
garberz
Bronco Influencer
Conejo Valley, Ca.
Fluke is the one I used, it's seems like a quality product. As for Harborfreight, I only buy their tarps. I've tried a few other thing there, never again.
