3spd won't shift while car is running
Shimmy
1977 Bronco
Maple Valley
attempted to take the car out for a spin today and quickly discovered that it would not shift into 1,2,3 while the car is running. i can get it into reverse if i slam it in. baffled why it would suddenly not work.
it shifts into all gears easily when the car is off.
the only thing i can think of that may have messed things up is we accidentally started the car in 1st gear and it quickly lunged forward and died/stalled out.
any tips or ideas where i should start here?
3speed manual with JD floor shifter that's been on the bronco since the coming of christ. never had issues
bmc69
I had that happen when the pressure plate lost a couple of the fingers (diaphragm style clutch) and would not fully disengage when the pedal was pressed. A similar event occurred when a "chunk" of the organic material on the clutch disk partially broke loose and was jamming up the clutch to some extent. That problem disappeared when the chunk of disk finally got thrown out, but alerted me to the fact that I had a worn out clutch.
Check for correct full motion of the clutch arm in the bellhousing first...
It can also be the stock bronco clutch rod, getting ready to fail.
They break at the bends between the pedal, and the bell crank out at the frame.
Generally, speaking, starting it in gear does not cause problems for the transmission, linkage or clutch. But when things get old enough, even a little extra jerking from that can take its toll.
When everything’s in good shape though, we often use the starter on purpose to get the vehicle rolling.
Shimmy
Shimmy
1977 Bronco
Maple Valley
took a quick spin again and it'll go into 2-3 gear when "rev matching" and back down to 1.
dirtdonk, are you referring to this part?
edit: oh clutch push rod! pretty sure mine is stock but i'll check that tonight!
That rod on the right, that goes up the floor, that was the one that I had issues with. Mine was so bad that the arm going to the pivot would bottom out on the frame rail. Yours is not as bad as mine was.
Have you tried adjusting the clutch yet?
.94 OR
Willamette Valley, OR
I'm betting there is something I'm not seeing. The pivot mount that bolts to the side of the block and the bell housing is only showing 1 bolt. There should be 2. It is also positioned in an odd angle from stock. I think the frame mounted pivot block has slotted holes so it could be out of adjustment as well which could be compounding any issues.
Shimmy
Shimmy
1977 Bronco
Maple Valley
adjust it at the bullet nose rod end? i did that a year or two ago and it was dialed in. would it all of a sudden get tweaked?
i suppose i could extend the bullet out but i recall adjusting it in due to the throw out bearing whining
Shimmy
Shimmy
1977 Bronco
Maple Valley
there's two bolts going into the block
Johnnyb
Flagstaff
Not to take this in a different direction, but when the throwout bearing starts to seize up, it has that exact behavior.
Shimmy
Shimmy
1977 Bronco
Maple Valley
not what i was hoping to hear but appreciate that info.
i took it for another spin and if i press on the clutch pedal hard and all the way to the floor it'll slide into gear. 🤔
appreciate the patience guys! i'm just dumb on this stuff.
If one of the nylon bushings on the clutch pivot decided to no longer be in the house, it could toss the clutch adjustment off a bit. A motor mount shifted a little bit. Body mount shifted some?
There is a lot of stuff it could be. It all comes down to the same thing. The clutch isn't releasing all the way. There is a little drag and the clutch disk is kept spinning and the syncro can't bring it to a stop enough to get it into gear. Reverse doesn't have a syncro, once the teeth crash into each other it is in gear and holds enough to force the disk to stop. Back when I had my clutch dragging issue (before I figured it out) I could get it in reverse, stop the transmission, and quickly shift reverse to first. Quick enough the clutch disk doesn't spin up in that brief pass through neutral.
For you I would start with an inspection of the linkage and adjustment of the clutch. clutch adjustment is a maintenance item, not a one and done deal. It needs adjustment as the clutch wears. Modern vehicles with hydraulic clutches are self adjusting. Even the old 5.0 mustangs with the cable clutch had a self adjuster on the cable. The Bronco is old school, manual adjustment.
What year is the bronco?
Was the V8 swapped in?
Did you paint the bellhousing, and if so, is it aluminum under that paint? Or cast-iron?
Looks different in a “non-bronco” kind of way. Like it’s smaller, and or maybe aluminum.
Maybe it’s just a different version of a stock housing, but it doesn’t look like the ones I’m familiar with.
I’ve never seen an engine-side bracket like that, holding the clutch bell crank. Usually the second bolt is a separate bolt into the side of the bellhousing. Not bolted under one of the housing bolts.
Maybe earlier models had this? It’s just a 66 by any chance?
Or maybe it was converted and a custom bracket fabricated.
Or, as is often the case, it’s just a standard one that I haven’t seen before.
As the others are saying, your symptoms are exactly those of a clutch that’s not fully disengaging.
Whether it’s a throwout bearing, a linkage issue, or just a simple adjustment, only you will be able to find out.
You need to get under there and shake, rattle and roll all the bits and pieces. Get up under the dash and inspect the pedal lever and rod connection.
Then see where that all leads.
Shimmy
Shimmy
1977 Bronco
Maple Valley
i see what you're saying about the crank support. it's a 1977 with a 302.
everything seems to be fine but i did notice the push rod was bent a little. i'm going to make an adjustment at the rod pushing the clutch fork and see where that gets me. i've only owned this bronco a few years so i'm not sure what's normal yet. the crank support has me scratching my head. i'm curious what it's off of now!
.94 OR
Can you get someone to activate the clutch while you monitor the linkage movement? Or video with your phone while you do it?
If all checks out, it is likely inside the bellhousing next.
Being a ‘77 is another possibility frankly.
Even though by then, Ford had the bronco pretty dialed in, it was also the last year of production. And lots of strange and interesting things are known to happen during the first, and the last years of production of many automobiles.
Maybe others with original 77’s can comment on their bell housings, and clutch linkage brackets.
Even though it looks potentially fabled, it doesn’t look like a hack job. Looks like something the factory could’ve done at the last minute by necessity.
Maybe there was a change of bracket because of that exhaust thermal control valve thingy at the end of the exhaust manifold on the driver side?
Shimmy
Shimmy
1977 Bronco
Maple Valley
well i haven't been able to get someone to press the clutch for me but i snapped a pic of the bellhousing ID. i think i'm dealing with a mustang housing here? hard to make our the numbers but i think it says D5DA-6394AB or maybe it's C5DA-6394AB?
also snapped a pic of the clutch equalizer bar and it's definitely got some "fab" work done to space it out closer to the clutch fork.
Yep, that has been modified. Don't know the bellhousing.
If you go into the Bronco and try to lift the brake pedal, how much play does it have?
Shimmy
Shimmy
1977 Bronco
Maple Valley
clutch pedal, no play. but i have to press it in like half way it seems before the clutch fork starts to move
