Reviving this thread... been running the 650 since last August, been *mostly* happy with it- seemed to take a lot of messing with the needles and springs to get it dialed in and still isn't quite right. Starts fine, idles good, runs pretty well except for right around 1200- 1500 rpm it bogs and falls on it's face. Once it works through that and gets closer to 2k it wakes up and starts pulling hard.
Most recently, took it to a reputable shop that has a lot of experience with Edelbrocks and the verdict they gave me was that the engine needs more carb. Seemed to think it's leaning out too much at that point in the powerband and starving it. They recommended going to a 750, which had me scratching my head as I questioned even putting the 650 on there in the first place thinking it'd be too much. On the carb'd version of this engine, blueprint puts a 600 holley on it and they felt the 650 would work just as well.
Only thing I keep coming back to is the accelerator pump, there's three holes to place the linkage arm into, have tried adjusting it without any noticeable improvement. The manual states the stock accelerator pump nozzle diameter for this model is .031". Are these interchangeable and would bumping up to an .035" solve my issue- anyone have experience with this, or should I be looking at something else here?
