FYI, I don’t know if this applies to your set up but I used a 1inch carb spacer plate to get the clearance required on my 66 to fit a stock air cleaner.
Good luck!
I've been using a complete stock '77 air cleaner on a 351 for about 20 yrs. and the only air cleaner/valve cover interference is the plug wire stand. No body lift or butchered hood. What kind of valve covers?
Like this?
Years back a few were using the dual-snorkel Mustang round air filter housings with corrugated hose run towards the front area. You could then fabricate your own intake area in either corner.
Same would apply to a single-snorkel intake of course, but would likely be easier to make work than the dual would, given the limited space to work with.
They were fairly low profile too, which obviously helps a lot with a Bronco. Most are likely going to be just too tall to fit under the hood.
Presumably you have at least some amount of body lift?
paul
Paul, there is someone on this forum who’s done that. I plan to get one for our Bronco to eliminate that open air cleaner roar. Those Mustang GT air cleaners aren’t cheap!
Years ago, I tried one because of the one on this forum. I believe it will fit under a stock hood with no lift (like my Bronco). Problem is the diameter of the housing. No way it will work with the stock throttle linkage setup.
Here is the thread with the 'stang cleaner installed. Note the absence of the OEM throttle linkage. Unfortunately the thread de-evolved.
https://classicbroncos.com/forums/showthread.php?t=300052
What is that one? Looks like you have a non stock hood?
X2. Stock hood.Are you talking about one of these?
https://www.spectreperformance.com/cold-air-intake-systems
X2. Stock hood.
Which one is that? I have looked through the webpage and couldn't seem to find that one. Can you tell me what the height is from carb surface to top? And how much body lift do you have? Thanks!
