??435 install question??
brut69
Brownwood
Hey I just installed a 2" body lift to make more clearance for my 35", "F-150 ps and 435. Need some advice on cutting the hole and the overall install. I've read most all of the tech notes but i thought any extra wisdom would help. Anyways thanks.
rjlougee
With a 2" BL you should be able to minimize the hole so only the shift tower itself needs to be clearanced around. Make the hole as small as possible and try and avoid cutting completely through the cross member under there.
You can also swap the rubber isolators in the tranny cross member so the thick ones are on the bottom and thin on top. That'll drop it a bit more and make m ore room.
Joe
68beast
Covina, Kalifornia
I tried that swapping the rubber trick and It didnt work for me, it threw everything outa wack and just seemed like the wrong thing to do. What i did was got a pic of the hole someone else cut out and i just copied it, but i then had to do a little more trimming once I was putting it in. I dont have a body lift and the hole will be considerably smaller with one. Ill see if I can get some pics up for you to get an idea of what it is going to look like. :cool:
68beast
Covina, Kalifornia
allright here are some pics of my NP435 coming up through the floor. Just imagine that the floor is 2" higher all around for your application.I had to cut about 7"s back from the crease of where the flat and angled part meet, but you wont have too due to the body lift so i focused the pics on the front of the hole I made. Let me know If you would like any measurements.
P.S. how do you like the cover im working on?
68beast
Covina, Kalifornia
I did have to bend the tranny shifter to get it to not hit the t-shifter or the dash. Due to the body lift you probably wont have a problem with the dash but may have to bend the shifter on the NP-435 a little to get it to clear the t-shifter.
