NP 435 install sanity check
muskrat
OK, I finally got the transmission in! Thats the good news.
Right before i stabbed it in, I stuck the shifter in and put in gear so I can spin the splines to get it in.
It went in.
Everything is bolted up. For giggles, I put the shifter back in to see how she will fit under the dash.
Now I can't shift through the gears. Is it because I don't have the clutch linkage installed and working?
I hope so. If I have to pull the trans back out, I'm gonna lose it!
Thanks for the feedback.
Dave
bax
Old Member
well Dave when you say shifter are you talking about just the shifter or the shifter cover. very easy to get the shifter cover on incorrectly
muskrat
muskrat
Just the snifter. I installed the shifter cover for the trans install.
Right before I slid her in to the bell housing, I installed the shifter through the floor cutout and put it in gear so I could turn the splines on front input shaft.
Finally slid in to place and I bolted it up.
That's when I put the shifter back in to check dash clearance and it wouldn't shift.
It's hard to say for sure. There are instances where a manual trans won't shift until you can release the clutch, but those are pretty few and far between. You can test that without the clutch though, I would think, by turning the output shaft again. Hard.
If you can't do that by hand, maybe one of those strap-wrenches or something? A pipe wrench would work, but could bugger up the shaft too, so you would have to be super careful using that method.
But if that's not it, better wait for someone that knows those trannies inside and out to chime in with some worst case/best case scenarios.
Good luck
.94 OR
Willamette Valley, OR
I have always experienced that the synchros have to line up and the non-synchro'd gears as well. Even fresh and rebuilt the NP435 is a stiff box. The shifter lever will likely need bent before you can try all gears anyway. Like DirtDonk mentioned, turn the output yoke to release some pressure and try again when you get the lever bent.
muskrat
muskrat
.94 OR, It's a used 435. I didn't rebuild it. I did pop the cover and look around, all was good.
The shifter is already bent to fit since it came out of a 73 bronco.
I'll get the clutch linkage hooked up and see if that helps. I'll also try to turn the output shaft to see if it releases some pressure.
I'll say one thing for sure, I am not pulling that trans back out! I'll keep cutting the tunnel so if I have to, I can pull the trans cover!
Thanks.
What! You don't want to get more exercise by bench-pressing 95 lbs or so of cast awkward to hold cast-iron?
Man, don't wimp out on us now. This is just getting good (from over here)!!;D
Just kidding. Understand completely. Get out the grinders and recips.
thegreatjustino
Red Head Grease Monkey
Stockton, CA
Trying to put an NP435 in while the transmission in gear and get the ball in the exact correct location is a nightmare.
If the transmission is in first or second gear, what's most likely happening when you drop it in is the ball on the end of the shifter is sliding into the groove for the third/fourth shift fork since that groove is still in the neutral position. Since the tranny is already in gear, it won't let you move the stick up or down or side to side.
Get a long screwdriver, shift the transmission back into neutral, and the shifter should drop right in to the correct location.
broncnaz
X3 its tough to get the shifter back in if the tranny was in a gear when you removed the shifter.
muskrat
muskrat
Thanks for all the responses. As always, this is the best forum for inspiration, and mostly help!
No way I'd been able to complete all the projects on my Bronco without the help of folks like you on this forum.
