NP 435 install question
muskrat
Hey all. Could not stab the np 435 into the bell housing.
I ordered a replacement clutch kit, the correct one for the 74 Bronco. I swear I checked the clutch by fitting over the input shaft of the NP.
Made sure the alignment tool went in. No issue, but some resistance going both in and out.
My wrenching buddy said that there are two clutch splines, course and fine. First I've heard of that, but it got me thinking, should I have ordered a clutch kit from say an F-150 with a 302 and NP435?
The stock three speed and the NP 435's output shafts are both 10 spline. But, the stock splines are straight up and down with sharp 90 degrees. The NP's are slightly tapered from the bottom to the top. We mic'd the bottoms and they were the same.
Any thoughts on this? Wrong clutch kit? Is there really a course and fine splice clutches?
Thanks for the feedback.
thegreatjustino
Red Head Grease Monkey
Stockton, CA
Stock three speed and 435 use the same clutch. I've done the swap probably a dozen times and always used the stock clutch disc.
.94 OR
Willamette Valley, OR
Mine married up.
Good thing I wasn't in a hurry because working by myself I would work at it a while till I ran out of cuss words then come back another day to try again with a new batch. Took me a while but it finally slid into place like it was supposed to.
Pa PITT
Stephenville TEXAS
.. Sorry but I know most of this will be elementary. But did you not just slip the new Disk onto the front shaft of the NP435 .. NOTHING BEAT COVERING ALL YOUR BASES..
. So if the disk fits the shaft. & then you used a stab shaft to center the clutch disk. Then all that should be left is spin the trans rear shaft to spline up with the clutch...
It should at some point stab.. & I guess you could triple check the Pilot shaft size.
I can not imagine the pilot being off .. But your already in a DOG HOUSE..
... I SPENT ABOUT 4 NIGHT TRYING TO STAB A CHEVY MOTOR INTO A CAR.. When every one was telling me there was only one set of Motor Mounts... Guess what there are 2 sets.
demesauce
Shaver Lake, CA
When I installed my NP435, I too had a headaches. I did the install by myself, engine was already in, and the trans was already mated to the dana 20. But like you, I couldn't get the input shaft to slide into the bell housing.
But after jacking the front of the engine up to increase the engine angle, the process was much easier. Try to match the angle on the engine with your transmission jack.
thegreatjustino
Stockton, CA
Much easier to separate them and just put the transmission it by itself. Just make sure you bolt something to the back to prevent the main shaft from pulling out.
muskrat
muskrat
Thanks for the feedback guys. I'm planning on pulling the clutch back out and make sure it works with the splines on the NP435. Thought I checked it, but maybe I didn't.
I started looking at the Luk clutch kit that I bought, part number 07-120. In my research this morning I also see part number 07-027. I'm not seeing any difference.
Anyone have any insight on this?
Thanks.
tabascom16
Salisbury, PA
I only know of one small block ford input shaft. 1 1/8 with I think 10 square cut splines.
It can be a real pain to get the input shaft to slide into the pilot bearing in the flywheel. You need to get the transmission perfectly square with the engine to allow the input shaft to slide into the pilot bearing. Are you getting stuck with about 1/2 to 5/8" between the mating surfaces of the bell housing and transmission? If so you are well past the clutch disc and getting hung up with the pilot bearing.
If you can't get through the clutch disc put the transmission in gear and rotate the output shaft to turn the splines on the input shaft until they line up with the clutch disc allowing them to slide in.
I've had much better luck attaching the bellhousing to the transmission first, and bolting the bellhousing to the engine second.
