NM_outdoors
- Nov 27, 2012
- 122
Well, the bronco project is going to start getting some attention again now that the days are too short to scratch much off the honey-do list. I did the rolling chassis last winter/spring and am ready to bolt in the freshened up 351w and have sourced (almost?) all of the OBD I MAF Ford EFI parts. Just purchased my 4r70w Baumanator controller (thanks to the mass buy discount on this site) and have decided to retire the old T-shift D20 and go with an atlas 2 speed tc. I've done as much searching/reading as time will allow but have a couple of questions related to the overall drive train and speedo connection options.
Given the increased overall length of this setup and with a 3.5" suspension lift, I might be on the edge of being too steep on my rear driveshaft angle. My plan is to leave the rear spring perches "floating" until I get the final ride height established so I'll be able to rotate/aim the pinion and shorten the rear driveshaft as needed. Somewhere, I saw the option of two lengths on the atlas. One being with no speedo and one with. The option with a speedo will cause the OAL of this setup to be even longer so I'm wondering what others have done to avoid that. Can I go with an electronic speedo gauge (signal off the VSS or OSS?) to save some length on the atlas? My understanding is the Ford EFI setup interfaces with the transmission/controller but it seems like I'm overlooking something there.
Also looking for some suggestions on 3.8 or 4.3 Atlas ratio with that tranny. Leaning toward the 4.3 but I'm going 4.88 in the diffs and plan on being able to do some crawling but will be using mostly as a trail rig in NM, CO, AZ, UT.
Here's a couple of pics of the project so far.......
