4R70W dipstick
Steve373
Can I use the stock explorer transmission dipstick or do you have Chang out to something different.
tasker
all knowing of nothing
NH
Using a lokar flexible one on mine
garberz
Bronco Influencer
Conejo Valley, Ca.
I used the stock dipstick and tube on my buddy’s build, but we’re also using stock manifolds. I think using headers is where you may run into issues with the stock dipstick.
Mark
sanndmann3
I used the Explorer 4R dipstick and have headers. Had to adjust the bends a bit but nothing too radical
Bronco-Brian
Lake Oswego, OR
I also used the stock tube plus dipstick w/o issue on stock manifolds. Had to tweak a bend slightly, and weld a hold down strap to it, but it fits nicely.
nvrstuk
PNW
Used an AOD dipstick. Works great and saved 150 bucks. :)
BroncoChicken
I used the stock dipstick with shorty headers. No mods. Bolted into the back of the head just like it did on the explorer.
Explorer worked fine for me, With a 351 it did need a new tab since the heads were higher. The Explorer cleared everything even without a body lift.
Casey835
I used stock on 351 as well with some tweaking, really liked the lokar but couldn’t get happy with how it read. Other than that I thought it was a quality piece. The factory look was nice with the stock one also.
Sent from my iPad using Tapatalk
betzgb
Does anyone have a Ford part number for the stock 4r70w dipstick with the small yellow ring handle at the end? I ordered a E7TZ-7A020-C but it has a "T" shaped handle and is shorter.
