my fault - had to go do some reading on modular vs windsor. I'm all schooled up now.
here's a discussion on the meaning of 4R7X
http://www.mercurymarauder.net/forums/archive/index.php/t-33039.html
but i'm not sure it is conclusive. The last post seems to have the final word:
You guys are all close but not quite.
First off the torque rating is in ft-lbs, NOT n-m's.
The 4 is the number of speeds
The 70 or 75 is the amount of torque capacity at the input shaft of the transmission.
The last letter varies.
The original one was a AODE, and E stood for Electronic control.
In the 4R70W, the W was wide ratio.
Then they had a 4R70W+ that started in the 1999 trucks when the 5.4L went in front of it. This trans had a unique treatment to the Forward Sun gear and the one of the set's of pinion gears in the planetary gear set. This is what the original 2003 Marauder had in it.
When the 5.4L 3V F-150 came out in 2004, they upgraded to the 4R75 transmission. They dropped the W rating since they all had that gear set. This trans had upgraded shafts, bearings, etc. They also added a turbine speed sensor (which is really cool technology). The 2004 Marauder got this transmission without the turbine speed sensor. That's why there is a little plug on the side of the case of the 2004 transmissions.
Now, the 2004 F-150 also came with a 4.6L engine. This transmission was called the 4R70E. It didn't get all the upgraded parts that the 75 did, but with the addition of the turbine speed sensor they wanted a way to seperate this from the rest of the 4R7x family, so they dropped the W and went back to an E.....
j
>>>>> here's another link explaining some internal differences that occured in 2004, although they/he is not as sure sounding on the 70E/75E thing>>
http://www.explorerforum.com/forums/showthread.php?t=188119 .............. also...thought I'd mention the 4.2 V6 did come with 4x4 F150's.... back a 4 or 5 years ago when I considered doing the 4R70W swap I found the '99-'03 4.2 4WD transmissions were a very good choice for the bronco... back then, I even found some people selling NewOldStock 4R70W's & they had a few of these 4.2V6-4x4 transmissions for $800 with convertors....I'm still kicking myself for not buying one of them....they were brand spanking new 1999 & 2000 model factory ford units........ below are a couple of links,, first has some good info & the second has a really good internal pics of all the 4R70W parts(see all links within that 4R70W rebuild diary) >>
http://www.lincolnsonline.com/tech/00080.html .........
http://www.explorerforum.com/forums/showthread.php?t=128800 ............... quote from first link>>•The BEST 4R70W trans that will bolt to a Windsor V8 is a '99 & newer 4.2 V6. It has all the best parts and the same number of clutches as the V8 mod motor transmissions. This trans has: best case, best accumulators, mechanical diode 1 way intermediate clutch, dimpled pan & extended pickup, 450hp capable gear set, best direct clutch drum, best direct clutch plates, best forward clutch wave plate good to 450 hp, best intermediate clutch (4 plate), best stub shaft). Just remember that for a car install, you must switch the manual lever to one from a car.
•ALL prior to '98 do NOT have the expensive mechanical diode 1-way clutch
