4R70W torque converter code
turbotim2
____________
I am looking for the stamped code on the original TC for this 4R70W I picked up. Can not seem to locate it, any ideas? Thanks!
spap
What were the differneces. does anybody know. just curious
T
turbotim2
____________
The differences I have seen are stall, diameter and bolt pattern.
It's been 20 years since I did the research. But I recall of the stock offerings there were 3 versions that work on the small block, You could tell the difference by looking at the turbine vane angles embossed in the shell. One was a right hand twist, another a left hand twist, third was straight. The stock Explorer was the good one. I left it at that.
If you really want to get into the proper engineering of a convertor the term that actual engineers use is the K-factor. It is a term rarely found outside of SAE white papers.
T
turbotim2
____________
I am not looking to get too technical but the parts stores seem to list 3 when looking specifically at (in my case) a 99 Mercury Mountaineer.
rocknhorse76
Bronco owner since 1993 💪🏻
Central WA
These are most likely the 3 choices you have. Go with one of the high stall options. The first one listed supposedly has a heavy duty clutch, and is the one I used when my transmission was stock and I had a mild EFI 351W. Oh, and my 4R70W originally came from a 99 AWD Mountaineer.
Straight and angled ribs, matches my memory as well.
High stall is fine. Still pulls well at idle. You can get away with high stall since there is a convertor lockup to bypass the stall at cruise.
spap
Thanks I used the stock one about 10 years ago, diff bolt pattern for modular motor maybe , didn’t want to get to deep just never heard of different one s
