It's been 20 years since I did the research. But I recall of the stock offerings there were 3 versions that work on the small block, You could tell the difference by looking at the turbine vane angles embossed in the shell. One was a right hand twist, another a left hand twist, third was straight. The stock Explorer was the good one. I left it at that.
If you really want to get into the proper engineering of a convertor the term that actual engineers use is the K-factor. It is a term rarely found outside of SAE white papers.
These are most likely the 3 choices you have. Go with one of the high stall options. The first one listed supposedly has a heavy duty clutch, and is the one I used when my transmission was stock and I had a mild EFI 351W. Oh, and my 4R70W originally came from a 99 AWD Mountaineer.
Straight and angled ribs, matches my memory as well.
High stall is fine. Still pulls well at idle. You can get away with high stall since there is a convertor lockup to bypass the stall at cruise.
Thanks I used the stock one about 10 years ago, diff bolt pattern for modular motor maybe , didn’t want to get to deep just never heard of different one s
