4WD problem
Ss76bronco
Hi everyone. I have a new problem. First time in 2 years I finally put 76 bronco in 4WD. It engaged ok. Drove through some snow. When I was done I could not disengage dana 20 out of 4wh with the twin sticks. I also couldn't disengage locking hubs as there was tension on the front drive trane. On slowing down on way home got a significant shake from 10 mph to 0mph. When I got home I jacked up front end and only then could I disengage. I counted the spins on the front and rear drive shafts and got what I think was close to the 4.11 and 4.09. Rebuilt C4, 33" tires, ford 9 and dana 44. Any ideas?
EricLar80
Sometimes you need to shift the transmission into reverse or neutral and get it to rock a little before it will shift out of 4wd. Don't force it. Also helps if you're not on a hard surface.
Completely normal. Gears are bound. Light pressure on the gear shift and blip the throttle is my usual release. Pressure on the shifter as you go into reverse also works, creep backwards in a slight turn and if that doesn't do it go forward again in the same slight turn. It's just a matter of getting the bind off the gears so they will slide.
Same goes for going into gear, if they don't line up at first a little drive will walk the gears into alignment.
Old Mile Marker hubs are the only ones I know of that had a pre-selector in them. You turn them where you want them to be and drive. Once the teeth line up or the pressure is gone they will shift. About the only way to get them in or out with a limited slip up front.
Johnnyb
Flagstaff
I don't know if anybody's ever PDF the original broncos owner manual. Per Ford instructions:
Back her up about 20 ft while turning back and forth. It'll disengage. By the way that's completely normal for a manual shift transfer case on any vehicle.
Sent from my Pixel 4 XL using Tapatalk
Ss76bronco
Ss76bronco
Thanks everyone. I think I also discovered something making it worse. I put new tires on the front. The rear are still the old ones and are about an inch shorter than the fronts. I think that would also explain the shaking vibration when coming to a stop?
jckkys
All 4X4s with no differential in the transfer case do this. My WW2 Ford GPW jeep was the same. They had Dana18 transfer cases that the Dana20 evolved from. They had to be GI proof so using them can't be too complicated. You have to be aware of your traction conditions. When on snow, ice, or dry sand the 4WD works well, but you have to get out of 4WD when you near dry pavement where 4WD will always get gear bound. If you fail to do that, just put it reverse, when it starts to move put it in neutral. Then it will slide right out of 4WD.
JB Fab
Different size tire will cause binding every time......
blubuckaroo
Grease Monkey
Ridgefield WA
Square cut gears will bind when loaded.
Our Bronco has 4.09 front and 4.11 rear gears now. The binding isn't nearly as bad as when it had 3.54 front and 3.50 rear gears.
I don't know if it's that the ratios are closer now or that the gears like being pulled rather than pushed, but it was an improvement.
