Help with ID'ing 4WD Problem
Bigtex76
Plano, Texas
Hi Guys,
I'm new to forum and need some help. I've got a stock 76 Sport and my front wheels are not engaging when in 4Hi or 4Lo. It appears the t-case is engaging because I can't spin the front driveshaft with the rear wheels on the ground when it's in 4Hi/Lo. Could be bad hubs or problems in the front diff??? What do I look for to isolate the problem?
Thanks for your help...
oleguy74
calif city ca
put it in 2wh/hi.jack front wheels off the ground,lock hubs.turn frount wheels by hand.if drive shaft turns,hubs ok.if not pull hubs apart clean them up and re-install and try again.
Bigtex76
Bigtex76
Plano, Texas
I'm assuming if the u-joints at the wheel turn and the driveshaft doesn't it's a diff problem? If the ujoints don't turn, it's a hub problem? Also, was the factory front diff a track lock or open? Just asking so I know how the wheels are supposed to turn when I spin them while jacked up in the front. I.e. both in same direction, 1 one way/the other opposite, or independently...
Thanks Guys.
WyleCoyote
If the u-joints turn then the hubs are ok, what will probably happen is you will turn one tire and the other tire will turn the opposite direction and the ds won't turn. This would indicate an open diff.
To check the Diff, have someone hold the other tire while you turn one tire and the ds should spin at that point if the tc or transmission is in neutral.
dave vh
Lock haven
i had a problem similar a few years ago. when i had pulled the hubs off and put back on. tried installing with hubs in locked then unlocked position forget which way worked or if it was just a coincidence that it started working then. no problems since. i am sure someone on here will know if it makes a difference. just a suggestion to try. no guru here. just a shadetree mechanic. learn by trial and error. 2/25/11 just checked shop manual, says to install hubs in the lock position
Bigtex76
Bigtex76
Plano, Texas
Thanks Guys,
I will try all your recommendations tomorrow night! I'm ready to get the drive train straightened out so I can focus on a lift and some rubber...
...Also, was the factory front diff a track lock or open?...
Could be either. For many years, a limited-slip was optional.
If there is still an axle I.D. tag under one of the cover bolts, you can see if it was originally delivered as an open or LS diff. There would be an "L" in between some of the numbers. Usually the ratio number. Example "3L 73" or some such.
After all these years though, you can't always trust the tag.
Bigtex76
Bigtex76
Plano, Texas
Update...
Pass side Hub is hosed, will not engage. Driver's side will engage. If I engage the DS hub and spin the tire, the drive shaft spins. But I can hold the drive shaft with my hand and spin the tire and it stops spinning. Both axles will spin when holding the driveshaft, but not the driveshaft. I'm guessing the clutch packs in the diff are hosed??? Let me know what y'all think...
