5.0 4 bolt pulley
bax
Old Member
I have a 5.0 with a 4 bolt balancer on it. I need a 2 grove / 4 bolt, v belt crank pulley that will line up with stock alt and PS. Did they make one?. Do I need to go to a 50 OZ. 3 bolt balancer to overcome this problem?
I was told they don't exist. I looked far and wide and never found a 2-groove 4-bolt pulley.
I took one of the common 3-groove pulleys, visited a brake lathe and soon had a 2-groove 4-bolt pulley. This was the clean way to do it after running for a year or so on a sawed down 3 to 2 groove emergency driveway conversion pulley, and spending that year or so searching for the non-existing 2-groove pulley.
bax
bax
Old Member
I have found a 2 grove 4 bolt pulley but the PS grove is in the wrong spot. So I guess I may be changing balancers.
bax
bax
Old Member
did you check out Miss March?
Yes and April and May but what doe's that have to do with anything?
Looks like march does not have the offset I need. Much like the one that was on it when I got it.
Daddy4zack
El Dorado Hills
I just took pictures of one that came with mine. can you give me measurements? of what you need? i will post pics soon.
I have a 89 5.0 that was converted to carb and Vdrive. I rebuilt the motor and went to explorer front dress and efi.. So i have the whole v belt front and dizzy and everything i took off. maybe some will work for you??
Aaron
Daddy4zack
El Dorado Hills
Hope this helps.
Aaron
