5.0 sticky throttle
SC74
My new street Bronco build has an explorer 5.0 with coil pack ignition. Everything works as should, but the throttle is sticky from idle. Once you get over the hump it’s smooth.
I unhooked the cable and it’s smooth. I checked the throttle body and it’s clean (brand new build).
When the motor is off, everything is smooth and easy. Once it’s running, the sticky comes back.
It just makes it hard accelerating from a stop. What would create the problem with engine running only?
I did re use the old IAC and TPS if that matters.
Any ideas?
I've had a throttle body (26+ years ago) that was sticky on the first crack of the throttle in the morning. The aluminum throttle body would cool off and shrink on the throttle blade. Clean the carbon out of the throttle body, better. Slight bump in minimum airflow finally fixed it.
The other throttle sticky issue I had was the cable. The cable didn't have a straight shot into the ferrule and the cable acted like a saw blade. Cut a groove and once deep enough the saw blade (the cable) would get stuck.
SC74
SC74
I have ruled the cable out. When I disconnect it from the throttle body, it's smooth. Also, I can duplicate the stiffness by hand at the throttle body with cable disconnected, and it's smooth with engine off while connected.
I cleaned it best I could while still on the intake using some brake cleaner and also lubricated the spring. It's smooth with engine off, so it must be the vacuum from the engine holding the plate from wanting to move.
SC74
SC74
FWIW when I disassembled my Explorer throttle body and discovered the bearings in it were nearly seized up. I followed this guys video below.
The bearings were 63800-2RS:
10mm inside diameter
19mm outside diameter
7mm depth
https://www.fasteddybearings.com/products/10x19x7-rubber-sealed-bearing-63800-2rs
This is very interesting. What symptoms did you have that made you find this video and inspect yours? It wouldn't hurt to rebuild the bearings regardless. Thanks for sharing!
1969
Reno, NV
I’m in the process of doing an EFI conversion and took it apart to clean it and noticed the bearings.
904Bronco
San Martin, CA
Factory, just cleaned up. Re-used factory TPS and IAC also.
Good. Reason I asked was I had a 70mm aftermarket TB that gave me issues taking off from a dead stop. I went to a factory Explorer TB and the problem was resolved.
ntsqd
heratic car camper
Upper SoKA
FWIW you can buy those 63800-2RS bearings from a lot of vendors. Even McMaster lists them. Being a "-2RS" bearing they're going to have a little initial stiction due to the rubber seals. That small of a bearing it should be minimal, but it will be there.
I found the same. I could not cruise at a steady speed with a 70mm (forgot the brand, BBK maybe?). I had idle, and too much throttle. No control. dropped to a 65mm I had on the shelf, didn't notice any lost power but did notice the drivablity went from garbage to good.
1969
Reno, NV
ntsqd
heratic car camper
Upper SoKA
For awhile. Then it won't be. Shielded aren't sealed, so if the bearing isn't exposed to grit & debris it could last a while. I wouldn't expect that in an engine bay. Would also be a tiny vacuum leak.
In some situations can either buy an "-RS" version with only one seal or can pop one of the seals out of a -2RS bearing. The unsealed/shielded side needs to be a clean environment for that to work and last. Again, not something that I would try in a throttle body.
SC74
SC74
I think she just needed a really good cleaning. I took it off the intake Friday night and decided to clean it more in depth and lube those bearings before tearing it down. The bearings did feel good by hand, so I scrubbed it with brake cleaner and even hit it lightly with some 3000 grit sandpaper to basically polish the inside. I lubed the bearings from the inside and outside. Put it back on and the pedal feels MUCH better. I have not driven it yet, but I can gently apply throttle by hand in the shop (I could not before). Hopefully that's all it took!
Don't know if anyone mentioned it yet, but another reason for a sticky off-idle throttle blade, is that, with the engine vacuum sucking on it especially (your comment about it being there only when the engine is running), a throttle blade that is closed too far when at idle, will stick in the bore initially.
The "cure" on certain models then, is to turn the idle screw in just slightly. This keeps the throttle blade from actually closing all the way into the bore.
This is not true of all Ford throttle bodies I don't think. But on some at least, what looks like an "idle speed" screw, is actually just a throttle stop screw. Keeping the blade from sticking.
The IAC takes care of the actual idle, working with the computer.
So if yours starts to stick again too soon, see if turning up the idle-speed/throttle stop screw fixes it.
Good job on cleaning it so good by the way!
That's what my BroncoII did. But mine was only the first crack on a cold engine. The aluminum housing would shrink as it cooled and stick on the steel blade. A tiny bump of the throttle stop screw fixed it. Didn't mess with the EFI. Still passed the IAC test, fully warmed up with no load unplug the IAC and the engine should stumble for a couple seconds and stall.
