Hey there. So, I'm tired of my carb, lack of power, always eating up belts and all the other stuff that comes along with an old 302. I found a wrecked 92 mustang with a 5.0 HO in it so i decided to grab it and all the parts off it that it would take to make the swap. I'm currently still working on the wiring (There's tons of info online about that so none of my questions are about that). But I am running into a few problems that I want to address before i get in too deep with the swap so I thought I would throw them up here because I know SO MANY of you have done this swap before and had to figure things out as you came accross them.
I'm starting off with a 1970 Bronco with a stock 302 and a C4 that I put in a few years ago.
The mustang is a 92 5.0L HO auto with a A9P comp. It had been in an accident where it was hit upfront. The drive pulley was damaged and water pump ruined so I will be replacing those but I did hook up the batt. and got it to turn over so I dont believe there is any damage to the crank.
I think I have the wiring figured out but I have a few questons about general function on and swap tech.
1. Do I need to run the Bronco oil pan on the 5.0L? If i swap, do i have to do anything to the oil pick up?
2. I took out the throttle linkage and pedal from the mustang. do you suggest using the stock bronco pedal or the one from the stang?
3. What have you guys done about using the radiator? I have a good bronco 3 core radiator and would like to reuse. How do I run hoses or mod the rad? What have you guys figured out that worked for fan clearance? ( not trying to break the bank with an electric fan here)
4. how do i use that 5.0L alternator in the bronco? what voltage regulator should i use? Bonrco or mustang?
5. i'd like to use the mustang PS pump. is it possible?
6. What about removing the smog and ac, how do I use the tenisioner? How to route the belt?
If you have ANY tips as all please let me know. I did do my homework and looked up tons of articles about this swap. most of them focused on the wiring and the moving of the radiator for clearance.
Thanks. I'm looking forward to your input.
-Matt
-Matt
