5.8L differences F150, F250, E series ?
EFI Guy
TheEFIguy@gmail
BFE
96 can be EEC-IV or EEC-V. Just depends on GVWR, CARB or FED emissions, alignment of the moon during production etc...
Just an FYI, if it is indeed OBD2 I have software to tune those in the works currently. Just in case you haven't completely ruled out Ford EFI and have a complete donor to work with.
Timmy390
Timmy390
Conway, AR
Good to know thanks for the heads up. I was thinking of keeping the PCM as it's new (remaned) just installed along with the wiring harness just in case.
Tim
needabronco
Prescott/Farmington
I pulled my 5.8 out of a 96 Van. It had the same E7 heads and cam in it that as far as I could tell came in every other 5.8 engine of the era, it also had 19lb injectors. Nothing seemed different to me? Mine had a wiped cam lobe and scored roller lifters but everything else seemed fine and serviceable. "IF" there's any difference between a van 5.8 and any other 5.8 I suppose the pistons could be? But frankly I seriously doubt Ford wasted the time making a separate engine just for vans.
