5 speed question & more
dclack
Ah. I wasn't sure what the v6 option was in the F150.
I'm pretty sure that the first 'v6' option offered in an F150 was the Ecoboost. Up through '96 the 6 cyl was the 300 (4.9L) straight 6, '97+ was only offered as 4.6/5.4L modular v8 engine.
You would be wrong by many generations.
In the early 80's there was the 3.8 V6 that was offered for only a few years.
Starting in '97 the base engine was the 4.2 V6. Both these engines are related and share the small block bolt pattern, but not the inbalance of the crankshaft so leave the flywheel with the engine.
cjcargo
Baltimore
.. Another Set up I have is a 1990 Ford 302 BUT IT'S OUT OF A TRUCK so we know that won't fit
What do you mean it won't fit?
There isn't any differance between a car and truck 302. The computer is suppose to be better from a car, but you just want the intake on the passenger side.
cjcargo
Baltimore
Did your Bronco have the six from factory? If so I always thought it would be good to switch in the inline 300CI. It's a good strong engine with good torque.
cjcargo
Baltimore
Sorry I should have read your first post again. Odds are in 76' you didn't have the six.
76Broncofromhell
Bronco Totalitarian
Grass Valley, CA
Grossly incorrect. 4.2L started in 1997. It has NOTHING in common with the Exploder/Ranger V6.
Correct!
Pull the V-6
Sell it.
Buy V-8 for Bronco
Agree.
To the OP, this is a stupid idea on so many levels. 60* V6s of that era are known initially for rod bearing issues, cracking heads (saw a lot of those in my machine shop days), and have the "Ranger rattle" valve noise (from lifters getting stuck, stopping oil from passing through the pushrods to the rocker arms and eventually wearing the valve stems causing a loud chatter). Did I mention I had to work with a fleet of V6 Ranger parts trucks?
The amount of effort needed to put a V6 in rivals that of swapping in a V8. They are basically a bored and stroked 2.9L. As said in previous posts, the transmission is a Mazda trans (M5OD-R1) and I have changed at least 10 of those pieces of shit in my lifetime. It is not the same as the M5OD-R2 seen in F-150s and Broncos.
The only 4.0L worth a shit was in the 1997+ version of the SOHC which I might add has to be the most difficult engine to work on in the history rivaled only by an early 3.0L SHO Taurus. The fact that this engine requires bypassing the PATS module and has 3 separate timing chains that each have tensioner issues and requires a $900 alignment tool. But I digress.
If you are looking for a relatively compact and easy OD to find, look for 1990-97 Jeeps with 6 cylinders and nab the AX15 out of them. Run that behind a 5.0L and you have a very streetable rig. The M5OD-R2's are OK, if you can find them, but in my experience finding a 4x4 version is pretty difficult around these parts. It's usually easier to find a ZF.
