x4 on the noise being misleading. But it's also misleading to be in a utility vehicle / metal box if your previous comparisons are with passenger cars or modern trucks.
In a Bronco an engine speed of 2500 can sound like 4000!
But just so you know, even with 4.56 gears and an effective tire height of say 30" tall, your engine is only spinning at 2,300 rpm or so at 45mph.
Absolutely nothing to be concerned with.
But that's why we verify gear ratios too. As said already, over this many years there is no telling what is in there.
Or you're actually in 4-wheel LOW! If so, that would really be screaming at 45mph!
Then again, you'd know if it was in 4-low because you could only go like 10mph before you think you're screaming your engine.
Even a temporary tach can get you by if you don't feel like mounting a permanent one.
Give us some more information:
1. What year is the Bronco?
2. What type of tires are they? Mud or All-Terrain? How old? Well worn?
3. What type of trans? Manual or Auto? All EB's were 3-speeds, but I assume you meant manual?
And finally, measure the exact height of a rear tire from the hub to the ground. This way once you have the gear ratio you can figure out your exact rpm without a tach using one of the online calculators.
This is the one(s) I use:
https://www.yukongear.com/calc_rpm.aspx
So before you get a tach (unless you want one anyway) verify your ratio and tire size. Then you can figure out the rpm.
And with the V8's, whether 289 or 302, some of us run the freeways at up to 3500 all day long and it does not hurt anything. Doesn't bother you as much either, once you know how fast the engine is spinning and that you're well within the safety regions.
But keeping it below 3,000, or closer to 2500 with a strong engine, or 2200 with a real strong engine and mostly stock-ish Bronco, would be even better.
Easier on the mind, and the wallet at gas stations.;D
