I did search but have not come up with anything.
I just rebuilt my 1100 original carb. Prior to rebuilding the carb, the truck had sat for years. After rebuilding the carb, I made the adjustments from this website
http://www.carburetor-parts.com/Autolite-1100-Adjustments_ep_416.html.
I also drained all the old gas from the tank, and installed a new fuel filter. Then I hooked everything back up, it started right up on full choke but died when the choke was completely pushed in (no choke). I adjusted the screw on the carb to engage the throttle more and was able to get it to stay running with the choke off.
I took it for it's first drive in a long time around the block. I drove it for a couple blocks and then while I was in second gear going maybe 30mph it all of the sudden started stuttering and died. It then did this all the way back to my house. I have driven it more to try to get as much info as possible on the problem. Here's what I've noticed.
- seems to die and stutter when it's above 1/2 throttle
- I can usually save it from dying if I push in the clutch and feather the throttle
When I was taking the carb apart to rebuild it, when I first popped it open, I had it flipped and I lost the check valve balls onto the floor. I found 2 of the balls on the ground but the rebuild kit I got had 3, so I installed the 3 into the locations shown on the rebuild kit. I bought the kit off eBay and I know there are many versions of the 1100. Did the original 66 1100 have 2 or 3 check valve balls. And which locations should they be installed.
I did come across a thread on here (can't seem to find it now) that mentioned some part of the 1100 carb that can't be accessed/taken apart but can be a potential problem. With my problem, could this be the problem?
Any ideas/thoughts on the problem would be much appreciated?
