66 170 dying
snick
I did search but have not come up with anything.
I just rebuilt my 1100 original carb. Prior to rebuilding the carb, the truck had sat for years. After rebuilding the carb, I made the adjustments from this website
http://www.carburetor-parts.com/Autolite-1100-Adjustments_ep_416.html.
I also drained all the old gas from the tank, and installed a new fuel filter. Then I hooked everything back up, it started right up on full choke but died when the choke was completely pushed in (no choke). I adjusted the screw on the carb to engage the throttle more and was able to get it to stay running with the choke off.
I took it for it's first drive in a long time around the block. I drove it for a couple blocks and then while I was in second gear going maybe 30mph it all of the sudden started stuttering and died. It then did this all the way back to my house. I have driven it more to try to get as much info as possible on the problem. Here's what I've noticed.
- seems to die and stutter when it's above 1/2 throttle
- I can usually save it from dying if I push in the clutch and feather the throttle
When I was taking the carb apart to rebuild it, when I first popped it open, I had it flipped and I lost the check valve balls onto the floor. I found 2 of the balls on the ground but the rebuild kit I got had 3, so I installed the 3 into the locations shown on the rebuild kit. I bought the kit off eBay and I know there are many versions of the 1100. Did the original 66 1100 have 2 or 3 check valve balls. And which locations should they be installed.
I did come across a thread on here (can't seem to find it now) that mentioned some part of the 1100 carb that can't be accessed/taken apart but can be a potential problem. With my problem, could this be the problem?
Any ideas/thoughts on the problem would be much appreciated?
norm02
You need the 3rd check ball for sure and then make sure your float is properly adjusted. Start with that and then report back.
ledslinger29
X2 on the float level. Sounds like it's flooding
