RVZIO
The rear tank uses a flat metal strap with a funky end that locks into the outside of the frame on the passenger side and a J-bolt on the drivers side that supports about midway of the tank. I just took one out!
Your earlier pics of the front show a 5/8" (roughly) vent hose with the large fill hose beside it. The early Broncos, '67 included did not have a vented fill spout and would burp when filling. There may be a chance that your filling system is from a later EB or something else entirely. So, if you have the option, and want to run a front tank, pick one up from a newer version that had the vent hose so it fills easier.
I was just looking at a tank kit from Bronco grave yard. Has the metal tank,sender, J bolts , strap, main fuel hose and a vent hose. Looks like all of that will fit. Thank you for the info
