Sounds like you'll be ok for the most part then. Still you need to add multiple grounds to enhance what was already a barely sufficient grounding scheme to begin with.
But the wires themselves sound like they may just serve you well and you can avoid the big re-wire project.
Maybe...;D
That big hole facing the middle is an odd one. It's on "most" Broncos, but has had different uses over the years. A friend of ours has a '68 (That's Brian's rig Doug) that actually has his main power wire run through there with no signs of it ever having been in one of the two main firewall plugs like normal. Very strange!
If it was not done at the factory, I have no idea how someone did such a clean job of re-routing it. It was very sloppy in the hole though, with no hint of a grommet or reducer visible. Making me think it was not factory wire routing, but the hole was definitely factory.
My '71 does not have one, while my '68 does. But on the '68 I'm not sure if it's factory or if 904Bronco put it there for the re-wire?
I can't really see it behind all the EFI stuff, so can't tell if it's exactly in the factory location or if it was added.
