Landscapepoke
Hi Everyone. Im new to the forum and this is my first post.
I purchased my 1971 Bronco back in August of 2015 from the family that my dad sold it to back in 1976. I have spent all last year tearing out the engine. had it cleaned up and the pistons re bored. I put it all back together with a friend and got it running back in July of this year.
Problem is I can not keep it from overheating. It over heats the most when sitting still. If I am driving down the road its ok. But if I let it sit and idol for more than 15 min, the minuet I stop and turn it off, pop goes the overflow cap on the radiator fluid overflow tank.
I replaced the water pump when I rebuilt the engine. Have the same fan blade on it that it came with. Put a new 3 core radiator in it, new hoses and a new thermostat. I have a fan shroud but its not much of a shroud. as it only has a top portion to it. I have 50/50 mix in it. Fan blade is on correct, it is pulling air through radiator.
I have read where the timing could cause extra heat to build up. I have it timed to just as low as I can go before it stalls out.
I've been told that I might have put a seal/gasket on wrong/backwards to block the water flow in the intake manifold??
I have also been told that there could be a tiny scratch on the bottom of the heads and it is letting heat into areas that it shouldn't go. Has anyone ever experienced this.
The oil is not milky so I know the head gasket is not blown and I had the radiator fluid tested to see if there were gasses getting into it. These two fluid checks have come out negative.
Short of pulling the heads off and putting new head gaskets on and refinishing the bottoms of the heads, I really would like to drive it this fall and winter.
I dont know if I have enough room to add an electric fan to the front of the radiator.
What am I missing or could I do. This is the first engine I have ever worked on in my life so I am new to the lingo and what to look for.
Thanks for your suggestions.
