Not sure why there are zero posts about the E-Stopp. Maybe cause it’s expensive and people don’t wanna post about how they do it, I dunno. I do think it’s pricey and I took a while to decide that’s what I wanted and looked at everything else available and seems like the best for what it is.
I really struggled with where to put this thing. It’s huge. A perfect spot might’ve been where the steps are on the drivers side if I didn’t have steps. This spot seemed to be the best choice for me.
I used a 4” wide aluminum stock to spread across the channels and mounted with stainless #14 screws into the channels. It’s plenty. My first version of the bracket, I forgot about the additional cable bracket and so had to make another that’s longer to support that.
There is no channel there so I had to make it find a bracket and I found a great one. Attached, not perfectly cause I had already drilled my holes for the bracket mount so it’s off center but it works.
Going through to the bed, I found these fantastic bolts that I used to mount my fuel pressure regulator in the drivers front. They are so low profile (yet still strong) that you don’t even see them there and you’d prob not notice these when done either.
My console will be shifter slightly and will be right at them.
Tested and works great. Need to decide how I want to wire it though. It’ll be active only when accessories are on, but there is a safety wire to connect if you want to not let it engage when the car is running and that seems kinda dumb. If I start it up I’d have to shut it off to disengage the brake? Maybe I can find something. I could probably wire up something from the ecu that gives power while in motion, like speed over X and that’s prob what I should do, although what if your brakes go out…don’t you want this to work? It would lock up the rears though so maybe I wouldn’t.
These are the bolts:
https://www.mcmaster.com/product/90357A015
This is the support:
https://www.mcmaster.com/product/1030A39
