Will try tomorrow. Iāll keep you informed and Thanks to allOr, as a quick experiment, apply the parking brake slightly.
Assuming itās not on already?
If itās off, applying the parking brake should tighten the shoes up and that will let you know if some of the long pedal travel is adjustment related.
However, sponginess is most likely air. Long travel can be multiple things.
Yes, the goal is for BRAKES to NOT = BREAKS.Just funning you, but BRAKES, if you broke something or it breaks, let us know.
My wife thanks you.
Looks like DirtDonk was rightBeen studying brake pressure. Some are saying 300-500 for light braking 600 - 800 on heavy brake and up to 2000 for a panick braking. Still waiting on my gauge
Mine is a 1āMC and stock peddle with a 7ā booster with a vacuum of 16 . Caliber gauge came in today hopefully I have time tomorrow to check pressuresMaking some gross assumptions on 1.125ā MC and 6:1 pedal ratio.
25 lbs of pedal pressure is 150 psi
150 lbs of pedal pressure is 900 psi
Above assume no vacuum booster, hydro, or engine off testing.
Yes I haveHopefully maybe you got it now!!!
Just to double check you are using disc to drum brakes proportional valve and not a stock H block meant for a front and back drum brakes?
Pressure gauge came in and had a little time to tinker yesterday. With front disks unhooked from MC I placed gauge on rear wheel cylinder and applied pressure on brake peddle and thereās 0 pressure and yes they are adjusted to drum. Went ahead and ordered new MC from WHYes I have
