It's very common to see rust just around the unit on the back of the clusters. Lots of times it's rusty around, but not under the mount, so it does not have a problem. But once that rust starts to intrude between the two parts it messes with things.
Since you're messing in there anyway, even if it's not loose I would remove it temporarily and look underneath. If even a slight amount of rust, clean it up good and then put it back on tight.
If you still don't get any voltage output, it's done and you need a new one.
But remember too that the originals were thermal switching devices that "pulse" between 4 and 8 volts or thereabouts, so a slow-reacting digital volt-meter might not pick it up.
If you don't have an old analog meter, try a test light too. Not sure what method is best, but the old analog meters really com in handy.
If it's not working, you can also play with the little adjuster tit/thingy on the back. Needle nose pliers and turn the rheostat adjustment to see if anything changes with the output. Worth a shot before buying a new one maybe.
