72 build for my wife
micked
micked
Sanded and painted fender well and frame
Took of rear brake line at the frame and old bump stops
Next will pull leaves off put on new springs and mock up axle and shock mounts on axle then tack them in pull it out and weld it all up
Most say 2-5 degrees of caster?
micked
micked
dhendriksen
What product are you painting it with?
micked
micked
Paintable undercoating
Speedrdr
Legend in my own mind
Paris, MS
How do you get the hard top to go in easier and further in... I have a huge gap between lift gate and tailgate... this is a different hard top than the original.... Sent from my iPhone using Tapatalk
The wagon tops or full cabs I’ve owned all had a gap that wide and the tailgate ‘rubber gasket’ covered up and sort of sealed it.
Randy
micked
micked
Randy
Great to hear that, I’ll get the gasket when it comes time for paint prep
Oldtimer
Jr. Member with Sr. moments
Sunnyvale, CA
Might consider getting it sooner rather than later.
That way in case your top is like so many, and has a bigger gap than the gasket can fill, you can deal with that first and not delay your paint prep.
micked
micked
I’ll order it up! Thanks!
micked
micked
New duff power brake kit installed
Just have to hook up the wiring and the vacuum line
I have a bunch of vacuum spots in the manifold to use and plug up… does it matter which one I use? Also I think one of th m goes to the valve cover on the other side that is missing a hose
