72 build for my wife
Wild horse 75
BC
The big tee that sticks out is where you should take the vacuum from. Those switches are actually in coolant so you could remove them and just plug the holes with pipe plugs.
micked
micked
Thanks!! I’ll do that! Appreciate it!!
micked
micked
Full-size 9” tacked in
Need to mock up the shock mount tack them in then pull the rear end out and finish weld the perches and lower shock mounts
micked
micked
Got new parking brake cables installed
micked
micked
Got adjustable track bar from duff on
Got dual heim joint steering linkage from duff on
Need to bleed the brakes
Ned to wire the line for new proportioning valve
Need to get rear pinion yoke off and put the new one in, but need to make a big ass breaker bar that I can bolt to the joke… it won’t budge cuz the little play when trying to unbolt that bitch
Then I can hook drive shaft up and take her for a spin
Looking to take it to a place to get a legit alignment … toe in/out, track bar etc … any recommendations for getting alignment in San Diego area?
micked
micked
Got the pinion yoke off by using a piece of steel and fashioning it to the yoke do the truck wouldn’t move
Bleed the breaks but one of the rear wheel cylinders is bad need to order one
Drove it around and it drives nice with the long arms and dual heims and track bar riser with custom track bar
micked
micked
New 17” wheels on 37x12.5x17 bfg all terrains
