Late reply, but been up to a few things. Rained a ton, so that sucked a lot of building time out.
Started sliders, added 1x3 right under the door sill after I cut the rockers out, luckily I did because I dropped the body on it last weekend and they held it all. Like mini sliders underneath my soon to be actual sliders. Hopefully soon here, but forecast reads constant rain all week and beyond so unlikely.
Fixed wiring issue, put a proper fuse block in and tapped into wires appropriately. Vs the crimp 3 wires into a spade connector and jam it into a fuse holder method..
On the trailer home last weekend the bikini top I had shredded, so we've got no top at all for now.
Switched out the old Ramsey winch this morning for my other warn, they both work but the Ramsey is just getting tired. It'll be a good trailer winch in the future.
Changed out the CB as well. Put my cobra 19 in there and wired my firestik antenna into the swing out tire carrier instead of the old magnet whip antenna. Hopefully this combo works better, it was awful before, I couldn't hear guys that were 30 feet ahead of me. No signal coming through at all.
Of course I have no pictures of any of this at the moment.
Still working on doubler plans, going to try and order a lokar dipstick, rock crawler gate for my Art Carr, and those triple sticks I'm eyeing. Need to see what high angle driveshaft parts I can get and see if anyone local is willing to build me a shaft using them. Going to upgrade joint size as well while I'm at it. I'm not sure what it has right now, but 14 bolt pinion yokes are super easy to find. I'll be throwing a u joint guard on there at the same time.
Hopefully I can make that a one weekend fiasco, with exception of the driveshafts.
