72 gauge help
bigdog137
Hi, 1972 gauge help please. I rewired the bronco, had the gauges working except the fuel gauge which had a broken needle. With the price of gas i didnt want to run out so I tore it apart and installed a new fuel gauge. Now I have nothing. I replaced the instrument voltage regulator, still nothing. I have power coming in and leaving the IVR.
I did replace the small piece of paper on the back of the fuel gauge, ( i believe it is just a gasket) with just an ordinary piece of paper when the original one was ripped? There wasn't something magical in the original was there? I dont know what it even is called. Any experts have any ideas? Thanks for your time, help get me back on the road please!!!!
billh1289
Jackson, NJ
When you say you have nothing do you mean the needle is on or below the E? Do you have 1 or 2 tanks? Did you check to see if you have power at sending unit? Check grounds?
B
bigdog137
Not movement at all in any of the needles. I have 2 tanks, and I switch back and forth, nothing, 1 tank is definitely full. I never thought about the grounds or the sending units. If I have power at the IVR that should be going to the gauges, right? That paper that goes between the two contacts,,,is that anything? Hey, thanks for your ideas? Sometimes I hit a brick wall and need someone to send me the right direction.
So before you only had a problem with the fuel gauge, but now none of the three work? I would say you have two problems.
One has something to do with the fuel gauge circuit wiring or sending unit, and now might have a new bad IVR.
But you said you have power going into and coming out of the IVR that you checked with a voltmeter?
Strange things are afoot. But let us know if I got any of that right
B RON CO
Statesville, NC
Hi, each gauge should be connected with a daisy chain to the ivr. Each gauge should have @6 volts pulsing on and off from the ivr. The other wire goes out to the sender. There is a cardboard washer to insulate the wires from the gauges. The whole thing must be grounded to work. Good luck
