73 Bronco T shifter question
malibubronco
I recently bought this 73 original Bronco. A local guy saw the T shifter
and thought it was shorter than stock. Any comments or help? thanks
It does seem shorter than some of the others I have seen. I'm new to
EBs...thanks
Viperwolf1
electron whisperer
EBs...thanks
Yep short. Does it have a body lift?
broncnaz
Yes very short it should be about the same level as the stereo. Body lift would be the main reason unless someone just decided to cut it down.
Todoubled
shouldnt be due to a body lift. the shift slot in the bezel isnt long enough to allow for full throw of the shifter.
What month was your Bronco built in? Probably a pretty early '73 as most came with the J-shift type setup.
If a later model, then a PO put in a different shifter and/or case anyway, so it wouldn't be too far out of bounds to have shortened the shifter as well.
If it's indeed original, you've got a good combo.
Does it shift well? Can you get it into all positions without running into the end of travel of the plastic cover?
Jonboy69
My stock 73 had a T shifter too. I think that is the short throw shifter that a lot of the ricers put in their cars these days. Does it also have an 8" exhaust ?
