73 riding rough
dblooseven
Hey guys just got my 73 on the road after many years. It rides really rough. I know its an old bronco and no where near stock but I mean its really rough. Maybe I expect to much. It has a narrowerd hi pinion D44 up front with stock coils and older monroe shocks. It has all polyurthane Duff bushings. Borgenson power steering and Duff rock cruher heim joint steering and Duff adjustable track bar. All this on 37 inch Irocs. I guess my question is would Duffs progressive rate springs make a difference and what shocks would be best. It drives pretty good just the ride is awful. any thoughts would be appreciated. Thanks in advance.
blubuckaroo
Grease Monkey
Ridgefield WA
A good 10-11 leaf rides way better than the old 5 leaf factory spring. Especially if yours has an add-a-leaf. Those things just put the whole spring pack in a bind.
Also, a good set of variable rate front springs make a big difference in your ride.
The downside to all this is that this cushiness will definitely affect the handling.
Now you know why anti-sway bars have been showing up in the catalogs.;)
bronconut73
Duff Springs and single Duff 70/30 shocks or Bilsteins.
Blu is very correct about the newer fat leaf packs.
He ran the stock 5/6 leaf packs with an add-a-leaf for a long time as did I. Loooong time....lol....but he (and me) switched to the fat leaf packs and its a game changer.
I am running all Duff suspension up front including their long arms. Running WH 11? leaf packs in the rear with RS 9000 shocks. It can be adjusted so soft that, as Blu stated, handling can become an issue.
Sway bars fix that but inhibit articulation, dual shocks can help too "and" not affect articulation but do stiffen the ride.
I moved my rear axle back 1.5" and it made more of a difference in ride than I expected. Noticeable improvement. Not sure if Blu has moved his rear axle back or not.
Crush
Greenbottom, WV
CHeck you tire pressure too. If you are running 30+ psi then it will be rougher. Most of us run mid 20's in the front tires and low 20's in the rear. 5psi makes a huge difference!!
D
dblooseven
The rear suspension is bone stock. I did move the axle back about an inch and a half but didn't drive it before that change.
How did you fit 37" tires? Massive cutting of the fenders? A 3" body lift? Both?
And while I have never personally used Iroc's, I'm sure some here have and can tell you if the tires are at least part of the problem.
As they said, new rear leaves will still ride firm, but get rid of some of the harshness of the older springs.
Probably the shocks have a lot to do with it too. Older shocks (no matter what brand) were pretty much not dialed in as far as street ride was concerned.
Not sure the regular 5100 Bilsteins are your best choice with that tire size, but they do ride very well on the street and retain a decent amount of control off road. Mostly for the lighter weight, lighter used Broncos. Not sure about yours.
Some like blu found them to be too soft (at least in the front?) even with his very moderately built Bronco. He's running "smaller" tires at 33" rather than your big boys.
But definitely check the air pressure right away. That's first, that's free, and that's a big deal with some tires.
PaveBronco
I second Paul's thought, how are you fitting those 37's with stock springs.
Pics would be nice, become a contributor and post pics.
Rustytruck
I think the weight and controlling the weight of 37" tires is killing your ride. A 100 + lb tire and wheel combo. Not counting a stiff ass side wall in the tire and your going to just bounce on down the road. You have the load C tire or one of the load E tires?
D
dblooseven
Yeah didn't know if you would call me on that one. You all don't miss much. Its not got a lift of any kind but it no longer has a bronco body on it. Its only Bronco where it counts frame and drivetrain. Not sure you all would appreciate pics of it. Don't beat me up.
Haha! Bring on the pics!;D
Heck, we're almost always interested in what others do with their builds. No matter what they built. And we enjoy "the hunt" too, when tracking down a problem and fixing it. Or in your case, at least making it less of a problem.
How old are the tires? Even otherwise soft tires don't ride as well once they've aged or mileaged out. And yours were already a possible issue.
When you get a chance, if you can still read the data on the sidewall, let us know what their load range is, and for those of us that don't have a chart, the load rating as well.
And check the pressures of course, as we've already mentioned. This is a huge issue with ride quality even with more modest sized tires.
Well, frankly it is with ALL sizes of tires.
