74 Build Thread....Updated.....3/14/13
66ALRIDE
66ALRIDE
Just BIP It!
Dothan, AL
Been busy welding up all the extra holes. Won't be using the old heater core holes, so beaux312 came by and did most of the welding on the firewall. Some had drill "alot" of extra holes in the firewall and floor. Welded up all those holes up and the ones we won't be using. Also got most of the old seam sealer out. Should start sandblasting soon.......
66ALRIDE
66ALRIDE
Just BIP It!
Dothan, AL
Got a little more done today. Finished removing all of the old bedliner with paint stripper. Next week will start sand blasting the tub.
JDJ
Dothan
Nice! I hope I get my rig back on the road before you completely finish this frame off resto!
JDJ
Dothan
He is slackin Pat!:-X;D%) But I can't say anything.....I am slackin on mine too
66ALRIDE
66ALRIDE
Just BIP It!
Dothan, AL
Ok Pat this is where I'm at now. Sandblasted the body and found alot of rust in the rockers. Replaced the rockers, sprayed epoxy on the body, started block sanding, priming, sanding, priming, sanding priming....... The tub is ready for paint now.
66ALRIDE
66ALRIDE
Just BIP It!
Dothan, AL
Also found pictures of this Bronco in another thread when it was owned in Mississippi Broncos post #50. Here is some pictures of the guide coat before sanding.
66ALRIDE
66ALRIDE
Just BIP It!
Dothan, AL
He is still undecided on the color. He started wanting a med blue metallic to a grayish blue and now talking about a satin charcoal. I told him had a little longer to make up his mind so we'll see..........
half cab
Guru Bronco
XX2 on looking good for sure....Pat ain't found the right yeller yet;)
JDJ
Dothan
Joey, good seeing you yesterday man! Some of us were begining to think you were in the witness protection program or something cause you just disappeared. Bronco is looking good!
BTW....he better hurry up and decide what color he wants, or you can decided what color YOU want it to be! ;D
