bmflinchum
Situation: 1975 was running (fast but running) went to drive it and it just stopped. No spark.
Not a fuel problem - replaced tank, sending unit, has new pump, rebuilt carb, filter etc and its getting fuel in carb.
Replaced plugs and wires before it died.
After it won't start I started replacing more parts:
Ignition module
Rotor, cap, coil, coil pick up
new switch.
Checked grounds. Tried checking everything I can doing searches on here and found some threads but no solutions. Even checked wires based on some diagrams found here.
I'm at my wits end. Almost everything in the ignition system is new and it won't start.
Any help will be appreciated.
Ben
Ignition module
new switch.
Ben
