- Nov 3, 2003
- 51,616
Keep an eye on those pesky mechanical fuel pumps still. They get old, they get tired, they get tired of sitting unused for extended periods, and especially with modern fuels it seems.
But from your initial tests at least, it appears it's still working well. At least when it's not overly hot. Only time will tell on that.
If it happens to you again in the same way, you might even try the old "when all else fails, beat on the carburetor" trick. Sometimes something just causes the inlet needle to stick in the valve and stop the flow of gas temporarily to the bowl. Rapping on it a couple of times with something will often "fix" it. Also temporarily, but enough to get you where you're going.
The tool used can be as simple as the plastic handle of a medium sized screwdriver. For awhile I had one screwdriver that really took a beating on the handle because every couple of days my Bronco would either not start, or would start and die, or would start and then flood out (needle stuck open in this case) and a few judicious smacks with the screwdriver handle took care of it.
You could literally hear the inrush of gas from the pressure side into the float bowl when the valve opened.
A metal tool like a wrench was the old standby, but the carburetor would look a lot worse for the wear after a few beat downs with a wrench. The plastic handles were much easier on the aluminum.
