'75Electric wiper motor problem?
reamer
Hi All, On a bench test I ground the black wire, then I apply 12 to the Blue and the motor spins...... then apply the 12 to the White and the motor spins slower,
On the truck harness, with key on, and wiper switch turned 1 click, I get 10v at the White, ...switch to high on wiper switch I get 12v. on the Blue.
This proves; 1. Motor works.
2. there is power in the harness with Key and switch on (in high and low positions)
So now I plug in the motor to the harness and I get nothing, Motor will not spin,, Even with a dedicated ground directly back to the battery neg terminal.
What am I missing?
Viperwolf1
electron whisperer
You should have 12V on both blue and white-black in their switch positions. This tells me you have a huge voltage drop in the switch or wiper wiring. Big voltage drop means a lot of resistance and not enough current to get your motor running.
The park circuit wires are not necessary to make the wipers run, so don't waste effort looking at those yet.
Did you ground the motor case? The Black wire on a wiper motor is not always just "the ground" for the motor. Might be something else.
Either way, add a battery ground to the mounting bracket, or motor case.
That sound correct Phil?
Viperwolf1
electron whisperer
Correct. None of the 4 wires on the motor is a ground.
reamer
reamer
Hi Paul, yes dedicated ground directly to the battery..
SLOWnEASY
San Diego, Ca.
Number one question is what changed? Did the motor work and this is just a replacement? Or did you install a new wiring harness and now the wipers don't work?
If I'm reading correctly you removed the motor and it tests correctly on the bench. Then you tested the voltages on the harness side and they all tested correctly. You added an additional dedicated ground straight to the battery.
If that is true then I can only think of two possibilities. The harness plug has a problem. Check that one of the wires is not sliding out of the connector as you plug the two ends together. If one end of the harness can have the wires removed then remove each wire and test if it sticks firmly into it's mate. The second is pretty unlikely but if you have an aftermarket harness it's possible your wires are flipped at the plug. I accidentally flipped the wires when working on my Neutral Safety switch because my brain kept flipping the plug alignment when looking at it while unplugged.
reamer
reamer
This is the original harness and a new wiper switch....
Viperwolf1
electron whisperer
Maybe I wasn't clear in my above post. Where you are seeing 10V, you should see 12V. I suspect something is damaged in the windshield frame harness. Perhaps you could bypass that harness to test that.
