'76 302 Fuel Pump bolts
No Hay
Ha! Just replaced the fuel pump on my '76 for the first time. The U tube video shows it, and claims it only takes 20 minutes. That was with the motor out on a stand. Mine took a little more than 20 minutes! I guess the next one could be 20. Standard ratchet set reached mine.
Hotrodjohn
with power steering I find it easier to go from below. I use a small 1/4 ratchet with 9/16 socket and extension to make it easier to move around on the two bolts that hold it in.
Readhead
Put it on top dead center to make it easier to go back in ... you will not fight the spring on the pump as much when you back in
