I have new master cylinder for an unknown application that want to use on my '77, but I don't know the diameter of the OE '77 Bronco master cylinder piston to see if this one is compatible. Is this spec available?
The piston bore diameter size is the only issue. Both fit the booster. I want the master cylinder bore diameter to be correct in relation to the wheel cylinder specs. I'll go with what Viperwolf1 said and make sure the new master cylinder has a 1" bore.
