Master cylinder bore size for hydroboost brakes
bigmuddy
bigmuddy
Marthasville Missouri
If you are missing the parts shown in post #36, they all are replaceable with out disassembling the hydroboost. Go to the powerbrakes dot com website, and read their tutorial on trimming and installing the pushrod.
I read it the install and trimming part which is what gave me pause when I pulled the old one apart. I wasn't expecting it to be that involved..
Check with them tomorrow. Thanks
catfan
Am I missing something , your new h-boost should only be missing the spring , retainer and rod and
those can be installed without taking anything apart ?
toddz69
Yeah, you don't need to take anything apart internally. Swapping the pushrod, spring and retainer over like @catfan mentions should take 5 minutes if you're slow....
Did learn something new in this thread though - I didn't know there were 2 different diameters of spider retainers.
Todd Z.
catfan
Todd Z.
Yes I bent a superduty one and made it fit in a mustang unit , I thought there was more than 2 .
bigmuddy
bigmuddy
Todd Z.
So, the spider and rod will pull out the front?
bigmuddy
bigmuddy
leave it to me to make it more complicated than necessary...
I assumed that since the spider "clips" into a groove it would need to be pulled from the back of the unit.
toddz69
Yes, use a needle-nose pliers and/or flat blade screwdriver to pry the little "legs" out. Sometimes I have to reshape them a bit before reassembling.
Todd Z.
nied4speed
roger that!
thanks Todd!
big muddy how did this all turn out for you on the brake system, I am about to the same point in my build and did not see an end to this thread, maybe I missed it. just curious if everything fit alright under the hood, and what did you end up with exactly for parts. thanks
bigmuddy
bigmuddy
I ended up using a compact wilwood unit that has 1-1/8 bore. Works fine and fits the space I need it in.
As others have said one with a 1-1/4 bore would have been better but you can't it, in compact size.
widowmaker77
Oldtimer linked the thread where this was addressed and yes it does change pedal ratio but I have made changes
to the bell crank since then .
@catfan. Can you send me some information on the ratio and what changes you have made? I also
Have one of your brackets with astroboost and Astro master. My brakes are good at the bottom of the pedal travel but feel mushy.
ntsqd
heratic car camper
Upper SoKA
@catfan
if you don't mind posting the pedal ratio here I'd be grateful. I know how to arrive at an ideal ratio for manual disc brakes (I've built a spreadsheet for it), I'd like to start figuring out an approach to doing it with H-B brakes.
ksagis
Aspiring Bronco Guru
Austin
We had a really long thread on this with @jamesroney some time ago when I think when he was installing one of catfan’s units. My take is 1.15 to 1.25 is roughly right.
But I think MC bore size plays in, and also the bore of the HB.
ntsqd
heratic car camper
Upper SoKA
The way that my mentor approached manual discs was overall leverage ratio. No reason that I know of that the same approach can't be done with H-B. Pedal ratio, m/c bore area, and caliper piston bore(s) area are all factors. The overall leverage ratio is easy, determining where the boundaries are is the hard(er) part.
catfan
The changes I made were to reduce pedal travel , I raised the b ell crank where it attaches to the brake pedal and lowered
at the h-boost side .
